I use my Uniden BCT15X strictly for aircraft, both VHF Civilian/Commercial & UHF Military monitoring. As usual I added a Par VHF-FM notch filter to reduce interference from strong FM broadcasting stations.
Recently I also added a Par VHFSYM152HT intermod filter. I don't know if pagers are still the problem they used to be for me at least. I grew up in N-W Detroit 1950-1982 before moving out. Pagers were a really big interference problem in the 70's +. Now I'm in Macomb, MI about 34 miles N-E of Detroit and I doubt pager interferance is as bad. But being a dedicated Airband scanner I figure it couldn't hurt. Anyone using this notch filter?
The Par VHFSYM152HT is scanner intermod filter that has a notch band of 152 to 153 MHz and a useful passband of 0 to 1 GHz. The notch band covers the offensive pagers in this range. The notch depth is up to >38 dB. Typically, PAR symmetrical filters have a 3dB bandwidth of ± 1.5% or roughly 2.25 MHz for VHF HI filters. Designed for receive-only, scanner use. BNC female input and BNC male output. Size: 4 x 2 x 0.75 inches. Made in the U.S.A.
[source]:
[source]:
PAR VHFSYM152HT Scanner Intermod Filter
www.universal-radio.com
