If they are on the same trunked system, you will hear everyone on it the same. It's the same transmitters and the same antennas, same location.
It's always possible for them to have a bad channel, or a bad antenna (which could affect more than one channel), but it would affect everyone the same, not just one dept.
Thanks for the reply. Well, not sure about that, or something I'm doing is quite wrong. and I certainly am not understanding how these systems actually work.
That particular system encompasses a large area. Some cities are 40 miles away on that " Parma/Medina/Ottawa County P25 System " and they aren't all running off the local Parma antennas. Parma, I'm maybe less than a mile away from their two antennas, and oddly the radio cars come in solid. It's the dispatch that starts out digitally garbled and usually clears up after a long moment into the transmission. Weird. I hear Parma Hts on that system perfectly as well. Not sure where their base antenna are or if they use the Parma antennas.
So, I have the whole Parma/Medina/Ottawa County P25 System on the scanner. Some that are close I hear them perfectly. Others, far away, not at all, Although at times and with good conditions, Wadsworth, Medina police/fire/jail and their Sheriffs in that area come in well. YET, on those days, Parma Dispatch does not haha.
So, it's literally just Parma Dispatch on that system that is wonky. The Broadcastify feed of Parma, is using a different scanner, and it works perfectly fine, although he is maybe a tad close to their antennas and is well up in an apartment building I understand.
I have improved upon this issue with antenna changes. (moving antenna outside of my aluminum sided house, improving the antenna to an outdoor discone ), So, I'm so closer. I'm just amazed I am having an issue with this. I'm a HAM and have been doing Local VHF/UHF and worldwide HF/shortwave Utility Monitoring since the 80s! I posted here in case I was missing something dumb. I'm thinking it's the scanner SDR (SDS200) being insensitive to the needs of the Parma Police lol
Anyway, this is nuts, I almost just bought another scanner that we KNOW works with Parma haha. And, I may still! I'm on a mission. But first. I'm ordering a +5 DBI Omni Base antenna for the 800 band, so hopefully that improves over this old no gain Discone. I'll report back when I can get that together.
Thanks again for your replies and for reading this. Any thoughts are VERY welcome.
