PC transfer file (system) format info?
A
ACU1000
Guest
Maybe I should put this in the software forum, and maybe you can tell what s/w this is from (but I dont know)... what I want to know is how I can deciper what each line and entry on the line is telling me.
Before everyone gets pantys in a bunch, I am not going to write yet another program, I just need to know how to debug some data.
I have some systems that are corrupt (showing groups that dont exist any more but are still reference in the file and GQKs that show something associated when there is not really supposed to be, etc) and I want to fix them.
Where do I find the file format info...
SYSDATA#,"New System 1","0","0","2","2","0","0","0","0","0","1","","10","1111111111","0","0","8","LAT0LON0ZLV10","",""
TRSDATA#,"0","0","1","1","0","0","","","","","","","","","","","","0","0",""
GROUPDATA#,"Group1","","","","1"
GROUPDATA#,"Group2","","","","1"
GROUPDATA#,"Group3","","","","1"
GROUPDATA#,"Group4","","","","1"
GROUPDATA#,"Group5","","","","1"
GROUPDATA#,"Group6","","","","1"
GROUPDATA#,"Group7","","","","1"
GROUPDATA#,"Group8","","","","1"
GROUPDATA#,"Group9","","","","1"
GROUPDATA#,"Group10","","","","1"
GROUPDATA#,"","","","",""
C,"20","20","20","20","20","20","20","20","20","20","20","20","20","20","20","20","20","20","20","20"
C,"1","1","1","1","1","1","1","1","1","1","0","0","0","0","0","0","0","0","0","0"
CHN,"","","","","","","","","","","",""
TRKFR#1,"","","","",""
TRKFR#2,"","","","",""
TRKFR#3,"","","","",""
TRKFR#4,"","","","",""
Attached is an example of a corrupt file that I have... Loudoun.txt From what I see in the file it shows 7 groups yet within the software I only have 5. What gives?
Another file attached is GQK9.txt... it has one group remaining on GQK #9 and that group has 82 channels in it. The file still shows a bunch of other groups - how does a corrupt file like this even work?
Is it possible that they work, but contribute to slow or poor memory allocation, performance, etc? They make no sense to me so I am calling them corrupt. Is this a Butel problem? Is this not a problem at all? Whats up.
Please, someone, help me.
  • Loudoun.txt
  • GQK9.txt
A
ACU1000
Guest
No one has replied, so I thought I would add some more info...
I know if you look at the file it appears to have 7 groups. However, in ARC it has 5. I deleted those other two and they dont appear when looking at the file in ARC. When you go to groups set up in ARC sometimes it says there are 5 of 5 groups enabled and sometimes it says there are 5 of 6 enabled (1 thru 5 are checked and 6 is pink.) To me this sounds like there is a problem with the file. I know I deleted those groups while in ARC.
Also I am noticing inconsistenceies with the first number following the group name...
in this case the number shown is 19
GROUPDATA#,"LCSO Dispatch","19","1","0","1"
what does the first number represent? This is what I desperately need to know.
Sometimes it shows up as 10, other times it shows up as the number of TGIDs in the group and other times it appears to be somewhere in between or greater than the number of TGIDs.
While we are at it, does anyone know what the third number indicates?
I know what the second and fourth numbers do.
Lastly, just so people know how I think things got messed up. I do a lot of deleting and pasting of groups and renumbering GQKs to make them line up in the order I want them to appear on the screen (ascending by GQK)... is this a bad thing to cut and past and confuse the software (and is there a better way to sort the groups to appear within a system)?
Probably more important, and more likely to be causing a problem (if there really is one), is this... I also keep all my files on a usb drive and one day I might be editing them at work and that night I might be editing the same file at home and the next day I might be editing it at work again and so on. I have the latest version of the ARC396 s/w at home, but not at work - does this create a problem? My work has locked down admin rights to my machine and I can no longer install software so I have no choice. I notice some files I have show a butel format V1.03A and some are V1.03 - so am wondering if editing the same file back and forth on two different versions of the software, the s/w is expecting one format and not the other and get confused (and corrupts the file so to speak)?
Please reply with any and all help.
kellykeeton
Oak Harbor, Wa
im kinda lost but let me guess..
So this is the data file for a uniden programming application, the application wont read all the data you expect out of your files?
I would suggest to ensure you have the newest version of your application. Then if you cant read off the radio or import from your files
take that file and put it into excel and reimport back into your radio to fix the corruption if the software.
freescan has a real nice clipboard import tool
slicerwizard
Toronto, Ontario
The deleted groups are clearly marked as deleted / non-active.
It's supposed to be the number of defined channels/talkgroups in the group.
Yes.
Maybe. Probably.
Code:
ARC246 MEM V1.03A - IMPORTANT: ARC396/246 MEM file format is proprietary information of BuTel Software The Netherlands (c) 2005
blah, blah
SYSDATA#,"DISASTER","53","0","0","2","0","1","0","","0","1","","","1111111111","0","0","8","LAT0LON0ZLV10","",""
format is:
system name, quick key, system lockout flag,
system hold time, TG/channel delay time, attenuator flag,
data skip flag, ?, ?, system type, ?, website, ?, group presets,
modulation, P25 mode, P25 level, location/radius, postal code, ?
TRSDATA#,"0","0","1","1","0","1","","","","","","","","","","","","0","0",""
format is:
ID Search flag, status bits flag, use end code flag,
AFS display flag, Icall mode, CC Only flag, fleetmap, ?,
base frequency 1, step size 1, offset 1,
base frequency 2, step size 2, offset 2,
base frequency 3, step size 3, offset 3,
alert tone, alert level, ?
GROUPDATA#,"FEMA","20","1","0","0"
GROUPDATA#,"NIFC / NIMS Fire","45","2","0","0"
GROUPDATA#,"DHS Interop","53","9","0","1"
GROUPDATA#,"Urban SAR (TF-1)","30","7","0","0"
GROUPDATA#,"Unidentified","10","10","0","0"
GROUPDATA#,"NTSB/FAA/TSA","20","3","0","0"
GROUPDATA#,"Mil SAR","26","8","0","0"
GROUPDATA#,"LE Common","20","5","0","0"
GROUPDATA#,"MED Channels","2","0","0","0"
GROUPDATA#,"FIRE/RSQ Common","2","4","0","0"
GROUPDATA#,"Misc Air/Med/Emerg","","9","0","0"
GROUPDATA#,"FED Common","","6","0","0"
format is:
group name, channel count, quick key, lockout flag, active / group exists flag
C,"16","45","82","11","1","19","30","3","10","13","21","7","1","1","1","1","1","1","1","1"
data is:
number of channels allocated (in ARC s/w only) for each of the 20 groups
C,"0","0","82","0","0","0","0","0","0","0","0","0","0","0","0","0","0","0","0","0"
data is:
number of channels defined by CHN lines in each of the 20 groups
e.g. this says that only group 3 has any frequencies actually defined
(82 of them to be exact, so there should be exactly 82 CHN lines in this file)
CHN,"155.1600","SAR","Off","Search","Off","Off","Off","Auto","Auto","FM","","SAR Coordination"
CHN,"154.2800","VFIRE21","Off","Search","Off","Off","Off","Auto","Auto","FM","","Medical / Fire MA"
CHN,"154.2650","VFIRE22","Off","Search","Off","Off","Off","Auto","Auto","FM","","Fire MA"
CHN,"154.2950","VFIRE23","Off","Search","Off","Off","Off","Auto","Auto","FM","","Fire MA"
CHN,"154.2725","VFIRE24","Off","Search","Off","Off","Off","Auto","Auto","FM","","(Narrowband only)"
CHN,"154.2875","VFIRE25","Off","Search","Off","Off","Off","Auto","Auto","FM","","Fire MA"
CHN,"154.3025","VFIRE26","Off","Search","Off","Off","Off","Auto","Auto","FM","","(Narrowband only)"
CHN,"155.3400","VMED28","Off","Search","Off","Off","Off","Auto","Auto","FM","","EMS"
CHN,"155.3475","VMED29","Off","Search","Off","Off","Off","Auto","Auto","FM","","EMS"
CHN,"155.4750","VLAW31","Off","Search","Off","Off","Off","Auto","Auto","Auto","","LE Mutual Aid"
CHN,"155.4825","VLAW32","Off","Search","Off","Off","Off","Auto","Auto","Auto","","LE Mutual Aid"
format is:
frequency, name, lockout, tone mode, tone frequency, tone lockout, attenuator,
alert tone, alert level, modulation mode, priority, comment
CHN,"1712","Sheriff TAC 1","Off","Off","Auto","","DTC"
CHN,"1744","Sheriff TAC 2","Off","Off","Auto","",""
CHN,"1776","Sheriff TAC 3","Off","Off","Auto","",""
format is:
talkgroup, name, lockout, alert tone, alert level, unused, comment
TRKFR#1,"0866.5500","","1","",""
TRKFR#2,"0866.5875","","2","",""
TRKFR#3,"0866.8000","","3","",""
format is:
trunked frequency, name, LCN, lockout, unused (was comment)
A
ACU1000
Guest
Thanks - thats exactly the info I have been looking for - but now that raises a few more questions worth asking...
Then how come if they are deleted / non-active, when I look at the system in the ARC software its telling me that a GQK preset is pink for group 6... when group 6 is supposed to be deleted / non-active ???
