marconi949
Should I get a "peak and tune" on my new Galaxy 949.
A 'peak and tune' is just like getting your car tuned up. It optimizes what's already there, makes it as best as it can be. It won't change things much, just makes it as good as it's design will allow, most radio manufacturers tune it that way to start with. If you expect huge differences in performance I'm afraid you'll be disappointed unless the thing was really 'doggy' to start with.
If anything is changed with the typical radio circuits it isn't a 'peak and tune' any more, it's a modification, it's been 'modded'. That's a whole different ball-game. Like adding a 4 barrel carb and a racing cam to your little 'Yugo'. And you'd better hope your 'mechanic' knows what he's doing. (Most don't.)
- 'Doc
As I always say, if you want more power, get your ham license, but if you want the best out of your CB, be sure you have your antenna, a good quality antenna, matched well with your CB with as low as a SWR you can get. Good quality antenna and coax will get you a long way. Best quality antennas you can get are like K-40 and Wilson. I would recommend not going with radio shack or cheap RG-58 coax, because these coax types cause lots of gain losses.
Pretty much, you can have an expensive, high quality radio, with a junk antenna and coax , you can pretty much bet the signal sent out will sound like crap. On the other hand, you can take a low cost, generic brand CB with a good quality antenna and coax, and it match it well with SWR....you will see a night and day difference with signal. Don't expect long distance with CB, as that's not what is intended for, but it will get you local highway and smokey reports if that's what you are looking for.
You have a good quality Galaxy radio, don't deminish its quality with an inferior antenna and coax.
I got it done "peak and tune" the radio was set at 2.8 watts,now its set at 4 watts, go figure ? .
Looks like it was set up to use an amplifier with scuh low setting
It never hurts to align and peak a radio out of the box. Will it work out of the box? Sure. But the assembly line also has a tolerance margin, and dialing things in a little tighter never hurts.The CB radio was purchase new in the box from a reputable Ham radio store,All i knew is that the Radio was not up to snuff like my Buddy's 949 witch he purchase at that store,
Once you understand an RLC circuit, you'll see that tuning a resonant circuit makes it more efficient, and allows it to run cooler by allowing the inductive and capacitive reactance to cancel each other out. Some of these circuits are pretty narrow banded and the assembly line gets them "close enough" ...... sometimes.It IS true, these radios can easily be uh.. "adjusted" to perform out of "legal" limits; but at that point, you need to concern yourself with what will happen if said "adjustments" take place.
Yeah, I have 3 Galaxy radios (959, 979, & 2547), all brand new out of the box, and all 3 needed tuning to bring them up to legal limits.
BTW, do not rely on the internal meter - get a decent SWR/Power meter and learn how to use it.![]()
While I do agree that the antenna makes up the larger portion of a quality station having decent range, I don't agree that the antenna can effect audio quality. I can pick up audio from a dummy load or piece of coax and don't even need an antenna, but it won't talk to the end of the driveway like that.Pretty much, you can have an expensive, high quality radio, with a junk antenna and coax , you can pretty much bet the signal sent out will sound like crap.
