SDRTrunk Picking Site Audio
SilentMarker
MS
I am running SDRTrunk on our statewide 700 trunk system. I have 5 sites coming in, but audio only comes from one site. Can I change which site audio comes into/out of the computer?
Enforcer52
Voice Of The Piney Woods
Lake Livingston, TX
You state you are monitoring 5 sites, are all 5 sites within 25-30 miles of you? Is SDRT locking onto the control channels for each site? Do you have an alias list setup for each site and listen turned on?
If yes to all the above questions then you should receive audio from each site.
SilentMarker
MS
@Enforcer52 all sites are within that range, they are locked in to control channels (showing yellow control), alias lists are set up, all talkgroups are set to listen.
Still this morning after I reset everything, only 1 site plays audio. All sites are recording but not all play audio.
Enforcer52
Lake Livingston, TX
Strange, I have 23 sites setup and all play audio. Never ran into this problem as long as alias was set up and listen turned on for TGIDs.
If you STOP the site that is coming thru, does any of the others then have audio? Have you tried one site at a time to see if they play any audio.
What 5 sites are you listening to and did you add thru RR database or manually?
How many dongles are you using?
SilentMarker
MS
So I realized this morning I have 4 sites coming in, one is a duplicate CC frequency.
I am using one dongle, I did add most TGID through RR, some were manually entered.
I just tried the sites one at a time, no audio on any excepted the one that usually has audio. I noticed no site shows radio traffic in the now playing section, except the only site I usually hear. I do see radio traffic under events and I hear it on my radio (official and allowed on the systemnot set up for NAS) when affiliated to the correct sites.
I will build a new alias lists and try that.
jtwalker
BEE00.1E8-1.22 (or) BEE00.689-1.13
My first thought is you don’t have enough dongles to cover all control channels and voice channels for all the sites. What is the highest and lowest of the frequencies on each of the sites? And what is the spectrum coverage of your existing single dongle?
SilentMarker
MS
Nope, lost them. I started editing the alias lists and back to only one tower playing audio. I guess no editing to keep more audio going or no audio and have the alias list corrected.
SilentMarker
MS
1 dongle, MSWIN system, Pearl River site, Philadelphia Site, Walnut Grove Site, Four Corners Site.
jtwalker
Which dongle do you have?
Enforcer52
Lake Livingston, TX
Using those 4 sites you would need at least 3 dongles to cover them all. Even if you want to listen to only 1 site you would need two dongles to get all the traffic.
ChannelNotes
Dongle 1 (Recorders needed for 100% coverage: 4) ​
769.409375<-- Lowest edge of dongle based on sample rate
1769.58125
1770.55625
1770.615625<-- Center Frequency For Dongle
1771.23125
1771.65625
771.809375<-- Highest edge of dongle based on sample rate
Dongle 2 (Recorders needed for 100% coverage: 5) ​
771.9625<-- Lowest edge of dongle based on sample rate
2772.00625c
2772.25625c
2772.48125
2772.55625c
2772.85625
2773.04375c
2773.06875c
2773.16875<-- Center Frequency For Dongle
2773.18125
2773.29375c
2773.31875c
2773.45625c
2773.54375c
2773.56875c
2773.79375c
2773.81875
2774.08125
2774.33125c
774.3625<-- Highest edge of dongle based on sample rate
Dongle 3 (Recorders needed for 100% coverage: 1) ​
773.425<-- Lowest edge of dongle based on sample rate
3774.43125
3774.58125c
3774.63125<-- Center Frequency For Dongle
3774.83125c
775.825<-- Highest edge of dongle based on sample rate
