KCChiefs9690 said:
Chances are nothing bad will happen. The reason why they tell you to turn off cell phones, etc is because they transmit RF energy. Things that transmit can mess with the GPS, compass equipment, and other navigation equipment. I doubt a scanner will disrupt anything though.
Yes, well, I think that now in the aeroplanes you could use your cell phone without causing any interference, because all the stuff is prepared for support interference, but maybe they just say no, because there's a change that a cable that has isolation, could lose the isolation or something, as it gets older or when it came new, so always there's a remotely chance to have interference in the cockpit, and they want to avoid risks, so RF stuff is forbidden.
Well, but to the guys who wonder, why they don't let receivers on board, is that some cheapo ones even if they are receivers, they cause interference, I was listening to my radio scanner, to airband, and there was a cheap radio clock on tuned in a FM station, and in one of the frequencies that I was listening to, there's intermod of that radio station, it was about 10 feet from me, and when they were talking into that frequency, I would hear the airplanes and that FM at the same time, and when I had the squelch at min, the intermodulation was much more strong than the normal, and reduced sensivility. I just mention it as an example of what can happen.
But well, scanners won't do this trouble, for sure but they don't know, and also I have this conspiration theory, that they don't want you to hear to the airband communications, when you are onboard, because sometimes there's some minor trouble, that might panic the passengers onboard. But there's United with aircraft communications in the entertainment system, as another member mentioned, so it might not be the case really.
I remember a movie, that an aeroplane has an emergency, but they just don't mention it to the passengers, and a passenger got a receiver for airband, and that he notices the stuff, and that he starts to get afraid and stuff, that the passengers get to know what's going on and the situation gets worse.
Hope you understand my points,
Luis
