Pinellas p25
Tryton
Largo, Fl
Just a heads up, Site 5 is now using 856.96250 for the freq. totally killed my feed when it changed..
Disnykng
Could this be the reason I cant hear any Pinellas FD calls. I just got a BCD436hp. I hear Pinellas sheriff, St Pete PD, Clearwater PD, Largo PD, but no EMS.
I checked the freq for all the sites and it shows the same ones as in the RR DB, but I dont see any ways to designate which freq is the control.
Ronaldski
MI DB Admin
Bay City MI
Anyone in the area send in a submission to update the database? Its everyone here that collaborates together to improve the database. ;)
This is why when programming radios at a minimum is to program in the control channel(s) and any alternate channel(s).
wise871
N.W. Florida
Right now I show 856.96250 as an alternate CC. Should I remove it all together or make it a Primary CC. I'm not understanding what is needed to fix the problem.
crash1
Tampa Area
you need to check services and check ems fire tac dispatch this is the reason you can`t hear ems
FLA2760
Hernando County, FL
Just for my information, is the Pinellas County SO using encryption on any of the dispatch talk groups? I used to be able to hear them when conditions were right on the analog TRS but I have heard zero since the move to the P25 TRS. Thanks.
mitbr
Tampa Bay Florida
None of the Pinellas County Sheriff disp talkgroups are encrypted some of the tac channels are though like surveillance ect.
Tim
tpredmore
Tampa Bay, FL
Do you monitor and hear other TGs on the P25 system?
FLA2760
Hernando County, FL
Thanks for the replies. I haven't been able to hear anything at all on the new P25 system. I have the PCSO and FD programed into my Pro 197, I think I'm too far away. I was able to hear them on the analog system pretty often.
tpredmore
Tampa Bay, FL
Thanks for the replies. I haven't been able to hear anything at all on the new P25 system. I have it the PCSO and FD programed into my Pro 197, I think I'm too far away. I was able to hear them on the analog system pretty often.
Digital signals do not travel as far as analog signals. If you were on the fringe with the analog system, you definitely won't hear the digital system.
