Almost all public service is conventional analog so your FT65 should be able to get fire, Sheriff, local PD. The data base should be accurate. If you want some amateur radio frequencies try the greens peak repeater. 147.31 PL 110.9. You should be able to hear it up there. You will be able to pick up southern fire districts it includes Pinetop. You should be in range of Showlow, County Sheriff, Probably State PD on 460.300 I 40 and south. You can also try some of the forest services state and local. They are not very active but you may be able to hear something. Enjoy your stay.
