Pirates
Jhkayakr
Virginia Beach, Va.
6925 AM 4/1/2012 00:15 now
WMPR , playing techno music SINPO 35333
6950 USB 4/1/2012 23:15- 00:15
Wolverine radio, great signal SINPO 55455
Niagaraeye
Niagara Region Ontario Canada
Receiving both those broadcasts here near Niagara Falls Ontario as well at roughly the same SINPO scores. Signal on 6950 uppr switched to a digital format at 00:40 UTC and off at 00:41.
Techno music on 6925 AM still present at 00:42.
zob-slantzero
North Central Ohio
Here is the SSTV image from Wolverine Radio tonight, it's not the best.
Token
Jhkayakr, if you follow pirates you might want to visit the the IRC channel #pirateradio on the Starchat server. We pass real time information about pirates that are on the air in that channel.
T!
hfflunki
West Michigan
i picked up wolverine radio here near muskegon mi
on easter it was fading in and out but i got 3 min of audio
bailchaser
Kern County, CA
6925 usb
Been listening to Red Mercury Labs on 6925 USB for while now....Doors and Tom Petty! 03:50 -05:10UTC. Good signal in the Mojave Desert (Cal City).
Token
Just prior to that (before 0200 UTC) Radio Appalachia was up on 6935 AM, it could also be heard in the Mojave Desert (a little north of you) but was a little weak and noisy. Red Mercury Labs was loud the entire time they were on, but the signal really came up after 0430 UTC, peaking at over S9 here. At about 0445 UTC Turtlehead Radio came up on 6925 LSB, so for about half an hour there were two stations on 6925, Turtlehead Radio on 6925 LSB and Red Mercury Labs on 6925 USB.
T!
Niagaraeye
Wolverine Radio
Wolverine Radio is booming into the Niagara Region of Southern Ontario this evening on 6925 upr. I tuned in at around 2:20 UTC and so far content consists of what appears to be material from the 1940's, 50s and early 60's. Great signal, very little fading and consistently at S 9 or better
kilokat7
West Michigan
Wolverine sounding very "good" here too tonight with a killer signal (as usual) and a great selection of "good" music. "Good" being the theme of the show tonight..
Token
Wolverine most often, almost always, has a "theme" to the show. Something all the songs have in common or say. And the music starts "old" and works up to newer stuff, not uncommon for him to start the show with something out of the 20's or 30's and end up in the 21st century. Most transmissions end in an SSTV image that continues the theme.
As normal, Wolverine has a good signal into the Mojave Desert of California tonight (May 20, 2012, 0250 UTC), S8 on the lows, 10 over S9 or more on the peaks.
T!
