PL.#
stvnd53
Banned
Toms River,NJ.
I AM LOOKING FOR THE PL.# FOR N.J JEMS 2 FREQ.155.340 FOR THE FOLLOWING HOSPITALS:NEWTON MEM.HOSPITAL.(SUSSEX CTY) ST.CLAIRS SUSSEX (SUSSEX CTY)ST.CLAIRS DOVER( MORRIS CTY) ST.CLAIRS DENVILE (MORRIS CTY) MORRISTOWN MEM.HOSPITAL (MORRIS CTY) HACKETSTOWN COM. HOSPITAL (WARREN CTY)
THANKS IN ADVANCE
DJ88
Brick Twp., New Jersey
PL stands for Private Line. It is a sub audible tone that is built in to the transmit signal of a radio system. The radio that receives the transmissions is set up to listen for and receive that specific tone. During a transmission, if the tones match, the transmission passes through to the receiving radio. If they don't match, the transmission won't pass through.
The reason for PL is so that two agencies using the same frequency won't interfere with each other when transmitting on their radios on that frequency. The frequencies would have different PLs. Therefore, if they were both transmitting at the same time, they wouldn't step all over one another. Nor would they hear transmissions from the other agency on that frequency.
This applies to your scanner also. When you program the frequency for, say the PD for the town you live in, and also program the PL for that frequency, you will only hear them. You won't hear any other town that may be using the same frequency.
PL (Private Line) and CTCSS (Continuous Tone Coded Squelch System) are the same thing. DPL (Digital Private Line) and DCS(Digital Coded Squelch) are the same. DPL and DCS have nothing to do with the new digital radio systems. It is just another form of PL. It works basically the same way and serves the same purpose.
As far as viewing them on your scanner, they aren't automatically built in. You have to know them and program them in with each frequency. After you program them, you can go back and check to see what they
are. And of course, you have to have a scanner that is PL / DPL capable. Most of the older ones are not.
There are also some scanners that will search for the correct PL tone for a frequency. I have a BC 785D and if I put it in Tone Search mode, when it stops on a frequency I don't have a PL for, it will search and flash the correct tone when it finds it.
Hope I have explained this so you understand. Someone else may have something to add that I might have missed. But that's it in a nutshell.
robbinsj2
Bridgewater, NJ
PL/DPL is the same thing as the privacy codes that you see on the family radios. It lets your radio ignore other radios that are not transmitting the PL/DPL that you have set. Basically, it gives other people privacy from you.
Two users using different PLs who transmit on the same frequency at the same time will still interfere with each other (assuming they are close enough to); the stronger signal will win. This is why the FCC requires portable radios to have a convenient button that opens the squelch (or changes it to carrier squelch / disables the PL/DPL?), and for mobile radios to revert to carrier squelch when the microphone is taken off the clip. The user is supposed to listen for other activity on the same frequency to cease, so that he/she doesn't cause interference when he/she transmits. (I believe this is an FCC requirement, not completely sure.)
Imagine that you could tune your ears to ignore certain pitches. If you're in a crowded room, you could tell your friend to talk at a certain pitch and you would ignore all others. Other people would still be able to hear your friend, but someone shouting near you (even using of the pitches you are ignoring) would interfere by overpowering the sound from your friend.
DJ88
robbinsj2
Good addition to my post and a clarification about the agencies interfering with each other. Great idea using "your ears" as an example. PERFECT !!!
