Please help with scanner model selection
theTastyCat
Hi all - let me say in advance how much I appreciate all of your expertise.
I've had an older, dinky, non-trunking Bearcat in my truck for about five years now. It served me well in the small town I used to live in, but now that I'm in Nashville, I'm aware of how much I'm missing not having a trunking scanner. So - I did my homework and the BCT 15 looks just glorious. Here's the problem: I had a beautiful custom overhead console made for my truck to house my Uniden PC68XL CB and my old Bearcat. However, I wasn't very forward-thinking, as the console can only accommodate radios which are 6 3/4" wide or less - and the BCT 15 is 7 1/4" wide. I've decided that it's impossible to modify my console without it looking completely ridiculous, so I've been looking for a similar scanner that will fit. The next-best thing I could find seems to be the Pro-2055. It looks pretty sad next to the BCT 15, but the best scanner in the world isn't the right one if it won't fit.
I've been a bit scared of the Pro-2055 due to everyone's displays failing, and it sure isn't the eye candy of the BCT 15. But, it fits. So - if you were in my position, would you get a Pro-2055 or is there a better model that's 6 3/4" wide or less?
Thanks so much,
Gerry
DaveIN
Founders Curmudgen
West Michigan
If I'm not mistaken, the PRO-2055, 2096, and 2054 are the same DIN-E size as the BCT-15 and 996. It looks to be the standard these days.
theTastyCat
According to radioshack.com, the pro-2055 is 5.3 inches wide and 7.2 inches long, as opposed to the Uniden, which is 7.24 inches wide and 6.06 inches long.
Oh, how I wish the BCT 15 were 5.3 inches wide...
rchalupajr
The RS Pro-2055 is a good scanner. If you are worried about the display problem, stay away from any manufactured in 05. Dave is correct, the models he mentioned are true DIN- E size. While the BCT-15 has a few more features, sound like the 2055 is more what you need for your situation.
theTastyCat
Perhaps I'm reading the numbers wrong - believe me, I'd jump at the BCT-15 if I knew it would fit in my console - but when it says the width is 7.24 inches wide, surely that means the measurement from side to side...I have read that the BCT-15 is DIN-E sized, but that 7.24 inches is 1/2" too wide for my console *sob*.
Here's the site for the BCT-15 specs:
http://www.radioshack.com/product/i...sories&productId=2476543&support=support&tab=
Same site, Pro-2055 specs:
http://www.radioshack.com/product/i...oductId=2123168&support=support&tab=techSpecs
So, if the max width I can fit is 6 3/4", is the Pro=2055 still the best choice?
Thanks,
Gerry
rchalupajr
The pro-2055 is also 7-1/4 inches wide, so looks like neither one will fit your application. what about mounting in or under the dash?
theTastyCat
According to the above link and all the rest I've found, the Pro-2055 is in fact 5.3 inches wide. Where does it say it's 7 1/4" wide??
rchalupajr
On the tape measure that I measured mine with...:D The unit measures 7-1/4 wide, 5-3/8 deep, (from front face) and 2-3/16 tall.
Obviously, the 5.3 is the depth, not the width. Radio Shack referes to the length, which is actually the depth. they have the length and width
mixed up.
theTastyCat
Great, thanks for clearing that up. Man, oh man - now I gotta think hard. Darn it! Oh well. Perhaps I'll conceive a way to fit it in.
Thanks again - you saved me two trips to Radio Shack!
