Plessy PTR1851A
mfn002
Bryan, Texas
I don’t know where to post this, so I guess I’ll post it here.
I recently bought one (out of curiosity) on eBay. I can’t find much online about it. It is a small, VHF man pack-style transceiver with a very small LED display on top. When I hooked it up to a standard 6 volt lantern battery, the display comes on and says “0”. I can’t get it to do anything else. Anyone have any information about this radio?
Sent from my iPad using Tapatalk
RFI-EMI-GUY
That radio, if you have it all, requires 28 VDC to operate.
Sent from my SM-T350 using Tapatalk
mfn002
Bryan, Texas
I think I should have posted a photo of the radio in question.
RFI-EMI-GUY
Oh quite a rare beast. Apparently capable of 16 kbps encryption! A keeper. The zero might indicate that it is zeroized, no encryption Key.
Probably not a 28 volt radio. You might search for Plessey Smalltalk to see if that brings up any documents.
mfn002
Bryan, Texas
As I said, it powers up on 6 volts. Anyway, the memory battery is missing, so that might explain the zero on the display. There is a small diagram on the side of the radio that shows three watch-type batteries stacked on top of each other. I just wish I knew what type of batteries they were.
RFI-EMI-GUY
Here is a similar radio, different nomenclature, but it runs from nominal 12V.
Back then, watch batteries wre mercury and about 1.35 V. You can probably get by on newer 1.5V lithiums.
http://radiohistory.uk/plesseyPVS1850.htm
mfn002
Bryan, Texas
Looks identical to the one I have. I wonder if mine is just a slightly newer version.
RFI-EMI-GUY
Did you get this radio powered up?
