POCSAG Paging
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
You will need someone to either find the interference blocking the paging signal in your problem area (assuming the signal values are correct) OR find someone competent in DAS to fix/fill in the missing coverage. TT
70cutlass442
You are going to have challenges. I just deployed a VHF P25 system. The repeater is on a water tower at 150', the hospital is 4000 feet away. We had to add another repeater to the inside of the hospital to make the portables useable. The noise floor in the ER was between -97 and -104. You are going to have to move the transmitter or simulcast. Whoever set this up for you guys had no business in doing so.
Well, -70 is not great but not terrible. Most lmr systems run street level at -70 in areas further away from TX center. That said a -.5 change with your amp on sounds a bit problematic. I would start looking at that first.
