POCSAG
RadioGuy3007
Good Evening,
Our hospital uses VHF pocsag pagers and we are having issues with coverage and we are waiting on an upgrade. Are there any 4G LTE pagers on the market that can do both?
K5DVT
Woo Pig Sooieville
What kb4mdz said. Maybe the antenna was damaged in a storm, or filled full of water? Even a moderate to high end antenna (~$2k) would be cheaper than a entire system overhaul...
Pittsboro IN
A scanner or CCR on your freq should be able to help you isolate the problem. If the signal strength indicator shows full strength but the audio is distorted the transmitter would be the most likely source of the problem. Low signal could be the transmitter or antenna system.
The wiring interface from the paging terminal to the transmitter could be flaky it's a long cable run like from the telco room on the ground floor to the top floor.
When we put in new VHF systems at VA hospitals we had backup systems including a second antenna. A mag mount antenna would be another way to isolate which direction to look at. Maybe the transmitter PA flaked out and you're only getting exciter level.
Thunderknight
Bletchley Park
High noise floor from equipment can cause a reduction in coverage by reducing the signal to noise ratio. E.g. if you are standing next to a computer spewing RFI on VHF, the pager has to hear the transmitter over that noise. Noise is usually worse on VHF than on higher frequencies (e.g. 900 MHz pagers).
But I concur with the KB4MDZ and K5DVT, the transmitter and antenna system should have a PM check to ensure it's at 100%.
WB5UOM
And maybe a couple of other possibilities....I did not see mention of frequency....maybe someone new showed up in the area if its not a "paging protected " frequency...or in addition to standard transmitter checks- modulation- including tone level out of the terminal itself....
and I am assuming its a single transmitter system.
just a thought
