Police Encrypted Radio detector
Ensnared
Waco, Texas
If you are worried about speed detection technologies, LIDAR, VASCAR, aircraft tracking, and even stopwatches are used in speed determining.
A Texas trooper once told me they set up on an elevated section of the highway & wait on the "high rollers." He told me that the simplicity of VASCAR was rather easy to beat in court. Texas still uses VASCAR.
prcguy
Police frequencies are intermixed or right next to other public service like fire, ambulance, etc, and business radios are also all around police frequencies. You would have to rapidly scan all the police specific frequencies to insure your not getting a hit from a bus or delivery truck or GMRS operator, etc. There is no way to use a broad band receiver and filter out just the cop stuff. And if you scan police specific frequencies you would have to scan thousands of them in a split second or risk not being informed there is nearby activity. Good luck with the project.
kb5udf
Louisiana
In some areas like mine, you can just monitor the control channel input of the state trunking system, because it is essentially all anyone uses here anymore for emergency services, including EMS.
wtp
Port Charlotte FL
monitor the input frequency, works for about 1 mile.
turn up the squelch, can bring the range down to a few hundred feet.
turn on attenuation, brings it down further.
take the antenna off, to really cut it down.
and if you do all the above at once....
they will be asking you what the radio is for !
AB5ID
Lee's Summit, MO (Kansas City)
You would only be monitoring input frequencies of the public safety system. Due to the RF sensitivity, you would likely only receive signals from less than half a mile away. If you could determine whether the P25 frames were encrypted, it might indicate that you picked up a police transmission in areas where only police communications are encrypted.
One potential issue is whether dispatchers also transmit on the input frequencies. If you were too close to a dispatch center, you might end up receiving their transmissions instead, which could be problematic. Do the dispatch centers transmit on the input frequency of the repeaters or are they linked by IP or some other network?
AB5ID
Safety of course, safe driving and situational awareness are key! I didn’t mean to hijack the thread from the original poster. I think we’ve ventured into the realm of the theoretical at this point; not for any nefarious reasons, but just to explore the strange thoughts that pass through our radio brains.
wtp
Port Charlotte FL
what i posted, i use.
and when my county went to 700 simulcast, i listened to the inputs as they are not affected by it.
AB5ID
No but the receiver probably requires FCC Part 15 certification.
Oh yes, because I'm sure all the RTL-SDRs, Airspys, and HackRFs have been meticulously checked for compliance. If not, I guess we're all just a bunch of rogue radio rebels, breaking the law one signal at a time.
BinaryMode
Banned
2600 dialtone blvd
User radios transmit their radio ID on the input frequencies. They have to or trunked systems wouldn't work.
I shall open a thread to this. Thanks.
I have a solution for this now. I monitor an aircraft ADS-B API from the Internet using a script that will flash a Philips Hue light bulb red and send a Pushover notification to my phone.
BinaryMode
Banned
2600 dialtone blvd
Yep, I learned that in drivers Ed. The instructor told me you have to go with the flow of traffic. So then if you go to court I guess you have to demonstrate that to the judge. At least I would. On the other hand if you do want to stay at the posted speed limit and not go above like all the other morons then you'd probably wanna stay in the right lane where you're really suppose to. But the most accidents happen there (on coming merging traffic). My instructor told me to stay in the middle lane so you can go left or right if you need to.
Project25_MASTR
TX-COMU
Texas
Except in far west Texas. Speed limit was 70, I was going 75, every other freaking car was flying past me (easily 80+)...I was told if I'm not keeping up with the flow of traffic I'm a hazard.
I mean...it's 75 on most Texas Interstates and many State Highways.
