Potential interference with speakers?
One thing i did do was setup my speaker system, right next to my cb setup, and i could not hear any interference...so i am guessing this would be the same for other speaker systems near by. So you are saying that systems that have not been tuned, will ultimately cause the interference?
It's the RF radiated by the antenna that is the issue. If you are running decent equipment that is properly shielded and connected to a tuned antenna, there shouldn't be a lot of stray RF near your radio.
I was suggesting that some "peak and tune" jobs are done by hacks that don't really know what they are doing. They'll hook up an RF wattmeter to the radio and start twisting slugs/spreading coils to get the RF power output higher. If not done correctly and with the right test equipment, all it does is result in a really wide splattery signal that looks good on an RF wattmeter.
If the tech doing the "peak/tune" knows what they are doing, they'll keep the RF power inside the channel where it belongs. Might not look as impressive on a wattmeter, but it works better.
Snitch321
When i was researching my CB setup, i ran a across a few stories whereby people mentioned that their power linear amp setups, causer interference on near by or neighbouring speaker systems. However, when i bought my 500W amp, and the pretuned Antenna (which supports 1000W) i have ran it without any interruption to my speaker system 2 feet away, let alone a neighbours speakers, so my question is, is this really true, is it something these people have changed or is it more due to poorly shielded speakers?
merlin
DN32su
With good equipment, proprly tuned, there is hardly ever any interferance issues.
Neighbors complaining of TV/stereo interferance, usually a good low pass filter solves a lot of that.
There are MANY variables, so the "didn't do it for me" thing only means your specific application/situation didn't suffer from that issue.
Poorly shielded speaker, long speaker wires that act like really good antennas on 27MHz, poor quality electronics, poorly shielded stereo equipment, different qualities of coaxial cable, grounding, probably 20 other things.
