Hello all,
Does anyone know what series (part number) of potentiometer "Pot" (Tocos brand) (vol/sel/sql) Uniden put in these handhelds. I'm currently having an issue where the unit is shorting out[ gets hot] and wondered if this was the issue. The leads on the pot/board are brown. Would like to purchase a replacement pot and see if this is the culprit. Do pots short out? The pot has five leads and is stamped with the number 22. Also near the leads is a paper label "R-b27" if that means anything. I also noticed on the PC board that "S101" is stamped on there in white if that helps too. Just need a little direction. Thank you in advance for any help you may have, Justin.
P.S.: This scanner is out of warranty.
