Think at least more like 2 wavelength’s spacing from a mast to get somewhat of an omni pattern and that’s about 12ft at VHF and 2ft at UHF. That would mean if a VHF antenna is off the side of a mast it’s 12ft out from it. If the VHF antenna is on top then a UHF could be below it only 2ft out from the mast and an 800antenna could be 1ft out.
For discreet single band antennas making a multiband system I like to use an 8 to 10ft pipe horizontal with a cast aluminum T in the center to hold the horizontal pipe to a mast, then cast aluminum right angle 90s at each end to attach short masts 1 to 2ft tall. Then the main mast sticks up through the T adapter a foot or so and the VHF antenna goes in the center of the 8-10ft horizontal mast. A UHF antenna will go on one end and a 700/800 antenna on the other end. This gives you a very good omni pattern with the UHF and 700/800 antennas usually being invisible to the VHF antenna with plenty of spacing for the UHF and 700/800 antennas away from the VHF. Plus all antennas sit at the top of the tower for best reception.
I have a partially assembled antenna system as described using all Shakespeare antennas starting with the fabulous HS-2774 broad band 136-174MHz used by the USCG, then it’s UHF mate the 380-490MHz US-3849 (very hard to find) then the 800MHz 4800-M which also covers 700MHz just fine. These all sit on a 1.3” OD aluminum pipe 8 ft long giving 4ft spacing between antennas and the whole assembly with antennas attached is very light weight. All antennas feed a Sti-co triplexer that will live in a small NEMA box right below the horizontal arm and combine all antennas onto one feedline. This setup is intended for portable operation with multiband radios providing noticeable gain over using a single broadband antenna like a Discone.
Here is an example of a cast T for 1 1/4” OD pipe or mast.
Hollaender Speed Rail Offset Cross | eBay
