I don't use powered hubs as I want to avoid injecting more noise with a switching power supply.
I power the following SDRs with this HUB with and a 20 foot USB 3.0 extension cable with no issues.
I have one of those, but the issue is that if you use a standard RTLSDR, you can only make use of two of them because two of the ports are too close together. It might work if you have Nooelec SDRs though.
