- Joined
- Jun 3, 2008
- Messages
- 866
- Reaction score
- 19
Hey all, i have a question re, AC power supply for my `436HP, the one i got at Dayton last year finally gave up today (started noticing issues with the scanner losing power intermittently, traced it to the wall wart), now for the question, the power supply i got at Dayton (which happens to be a cellphone charger, nice
) outputs at 5.0 to 5.5 volts at 100mh, and the one i`m now using (experimentally, hence my asking) outputs 5V at 1A. My question is, one, can i run this power supply withoug hurting the unit, so long as the voltages match? and two, regarding what i believe is just the way they`re charactarizing the amperage output, does the unit need to see a 100mh current or can i safely run a 1A (amp) current? would like to know so i don`t hafta find an OEM supply since it seems i could just use a cellphone charger with the cable that came with the original supply (the one that`s flaking out, tried it and it appears to work, and i really don`t want to hafta wait just to snag an OEM supply or god forbid turn a really great scanner into an expensive paperweight). So any help would be greatly appreicated
. Thanx! N9NRA P.S. The supply i`m now using is also a cellphone charger
