PPS Enhancement Suggestions
I would like to request Unication to consider some PPS enhancements.
Regarding D4 – Group ID Setting:
  • Currently, the only descriptive field in PPS is the “Group Alias” that is also displayed on the pager screen when the pager lands on a talk group. Initially, a user may enter into PPS five talk groups for an agency, and later, may need to add one or more additional talk groups for the same agency. The first five could be numbered 10 – 15, and the next entries could be way down the list such as 180 – 184. I would like to see an additional field such as a “Group” or “Agency” field (not sent to the pager during programming, but only maintained in PPS for user convenience) that is capable of being sorted. This way, the user could click somewhere on a button or the column heading for “Group” or “Agency” and the list would then sort so the user could easily see the talk groups that have been entered for an agency or system. For example, after sorting, the user would see the talk groups sorted as: OSP District 1, OSP District 2, OSP District 3, and so on. Currently, selecting the group heading highlights the Parameter Description for the selected column heading. Possibly add a sort icon to the column heading or add a sorting button at the top in between the “Custom tone Setting” and “Import” buttons.
  • I would also like to see a “Description” column where the user could enter talk group notes with up to 75 characters including spaces.
  • Possibly change “Alert Tone” default to “None” unless there is a need to keep it as “Default Tone” for public safety users.
  • Add code to the talk group entry windows to allow the “OK” button to trigger when pressing the Enter key on the keyboard.
Regarding D2 – Conventional Frequency Setting
  • Add sorting capability for the “Frequency Alias” column.
Regarding D2 – P25 Trunking System Setting
  • Add sorting capability for the “System Alias” column.
Thanks!
Bill
bob550
Albany County, NY
I certainly second that request to add ability to sort D4! This would be especially helpful when adding a TG to an existing system. It would also be helpful to be able to insert new TG lines where desired.
radio3353
My hand is also up for the ability to sort the Group Alias column in D4 or inserting new lines anywhere in the list. I would really like to be able to keep alias names together for each system rather than just being added to the end of the list. Thank you Unication for considering this (and MonitoringDelCo for starting this thread.)
N0GTG
Scanner programmer since 1997
Denver, Colorado
I would like to be able to export the talk groups and conventional frequencies to an Excel spreadsheet, make changes, and import that modified data back to the PPS. That would also make it much easier to build a summary of the programming to print out, and carry.
ffexpCP
wizard of odd
Michigan
I'd like to see PPS use a normal 'save' system where the user selects the location of the file. Something that would allow for network file sharing and backup. Having to import and export through the program is awful. It appears user data is embedded somewhere hidden. I recently had a computer crash and all of my PPS data was lost since there's no way to access the files to automatically back it up. Ideally, I'd like to specify a folder that's connected to a cloud service, so I always have access to my most recent versions of my files no matter where I am or what computer I use.
ffexpCP
wizard of odd
Michigan
Within the pager, I'd like to see options for user-select tones for alerts.
radio3353
When you click the Export button, don't you get a pop-up window to select the save location? I do. Or, am I not understanding your request?
ffexpCP
wizard of odd
Michigan
That's fine if you want to deal with importing and exporting with each use. Seems too easy to mess up and use the wrong version of the programming doing that, since you will have original fines in PPS and the imported version. Something will get lost.
