PPS / Radio Reference Interface
GJTA
Avon, Ct
Gary J. Therkelsen
Mar 11, 2026, 20:27 CST
G5 PPS V00-04-00-36 Am trying to use the Radio Reference link to import Massachusetts State Police trunking system. (| have the premium radio reference account). I selected the state and statewide as opposed to a county. In step 2 selected P25 Trunking Systems and instead of populating a drop down window with a list of trunking systems, it displays no data. Have changed the state to several others and with same process, receive numerous P25 Trunking Systems. The strange thing is if go to a browser and look for Massachusetts State Police trunking system, it appears. Just not when going through PPS.
K9KLC
Southwest, IL
Out of curiosity, did you try it by the county? I'm not from your area and have no idea what you're trying to receive but I've usually done IL and MO, thru the counties to get the list to populate.
GJTA
Avon, Ct
Yes, I have tried by county with same results. I've had these radios for years and have set up many profiles and never had this issue. Radio Reference says the problem is on the Unication side of the interface.
jtwalker
BEE00.1E8-1.22 (or) BEE00.689-1.13
Can you post a link to the system from RR to verify what I am about to tell you is correct?
The state police system I see for Massachusetts is a SmartZone system which doesn’t work on Unication G pagers. I’m not familiar with the area, but this is what I see from DB.
cubn
Search, Listen and Submit
Marion/Johnson County, IN
The Massachusetts State system is not a 9600 baud APCO25 system. Only those systems show up to download to the Unication radios.
Massachusetts is:
System Type:Motorola Type II SmartZone
System Voice:Analog and APCO-25 Common Air Interface
K9KLC
Southwest, IL
Aren't there two systems listed for the state police or am I reading this wrong?
Commonwealth Of Massachusetts Interoperable Radio System (CoMIRS) Trunking System, Regional, Massachusetts
I honestly don't know what's going on up there.
Maybe it varies from county to county and we do not know which county he's trying to add...
Nascar18
Southeast Massachusetts
The CoMIRS is the P25 phase 2 system of the future!
The western part of the state is running P25. I would say from Springfield to the NY border.
The rest of Mass. will be completed around 2027.
I think you can find CoMIRS in the Worcester county site.
GJTA
Avon, Ct
You have it right - I had it wrong.
I called it by the wrong name. I upgraded PPS to latest (44) version and can now see it. Wasn't visible in 36.
Thanks for the help.
GJTA
Avon, Ct
Thank you
