PPSTN site question
ve5wil
Moose Jaw
Hi guys, I am in Moose Jaw. I monitor both the MJ local and the Pasqua towers.
now here's a question... It seems there is no data channel broadcasting (been like this a day and a half so far at least ) Neither my BC 996XT, BC 396XT, nor PSR-800 can find one. I dont recall hearing any audio either. If these towers are down, what is likely next best option to hear the local traffic?
could there be new data channels in play?
as an aside - the psr-800 picks up MJPS when not encrypted and programmed as conventional
Wil
bush_man
Oungre, Saskatchewan
Are you scanning wide open to find the data channel? I am just making sure, I can change it if you find the new control channel, send a submission if you do.
Kel
Southwest Florida
No change in the data channels Wil,are you recieving EMS and Fire?give me a text if you are still having concerns.Kel.
mobile_1
This data from site 181 shows site 84 is also up and running with the others in your area on October 14, 2013
FileVersion:7
-TowerInfo
#This section is here for information only. With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID : 00A
System Name : PPSTN
WACN : 0000A
Tower Number (Decimal): 181-181
Tower Number (Hex) : TB5B5
Tower Description : Pasqua
Control Capabilities : Data,Voice,Registration
Call Sign(s) :
Timestamp : Mon Oct 14 10:20:05 2013
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,138.00000,0.00500,-0.64000,"Confirmed",0.01250,1
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count
"00-0006","av",138.03000,"00-0804",142.02000,1,2
"00-0042","c",138.21000,"00-0840",142.20000,1,0
"00-0072","av",138.36000,"00-0870",142.35000,1,3
"00-0144","av",138.72000,"00-0639",141.19500,1,2
-Neighbors
#Format: TowerID,TowerIDHex,System ID,Channel,Frequency,Tower Name
505,"T0505",00a,"00-0228",139.14000,"Regina"
5555,"T3737",00a,"00-0096",138.48000,"Craven"
8484,"T5454",00a,"00-0126",138.63000,"Boharm"
127127,"T7F7F",00a,"00-0150",138.75000,"Kill Deer"
182182,"TB6B6",00a,"00-0255",139.27500,"Buffalo Pound"
183183,"TB7B7",00a,"00-0180",138.90000,"Avonlee"
184184,"TB8B8",00a,"00-0225",139.12500,"Mortlack"
