I'm a bit puzzled and could use some help. I'm currently a 10 year RF Transmission System technician in the USAF. I need to tie in a PRC-113 Radio using the audio port on the radio to a switch. Basically what I'm attempting to do is take a 250 handset and womp off the handset and solder or splice on some wire I can crimp into an RJ45 connector to plug into my switch. I've found the pin out for the handsets connector but I'm unsure how that correlates to the color code I need to put in my RJ45. I've found the cable I need online but I'd like to test my theory before I spend the funds on a good idea. Any help would be greatly appreciated!
