Baofeng Preemie Newbie.. How do I upload NOAA Channels to my Baofang UV5 R
ASU6771
Walton, FL
I’m so sorry for this post. I just joined.
Got a Baofang UV-5R
I’d like to set it up by uploading different NOAA channels
as a simple test to understand the process.
How/where do I find the database csv to upload?
Then as a next step like to add channels to the GMRS frequencies. Is there a date base I can upload to the radio?
Then eventually possibly some local Fire EMS databases.
But I figured I’d ask that roll your eyes question, of how to I start setting up the radio via databases?
Thanks for your patience and gentle hazing, lol
Any actionable help greatly appreciated.
Thank you.
merlin
DN32su
Easiest way is with chirp or the OEM programming software.
I just keep a gap between amateur, weather, and GMRS channels (100s, 200s, etc)
ladn
CHIRP (actually now CHIRP New) has, as I recall, preconfigured presets for NOAA WX, GMRS/FRS, channels. Copy/paste into your channel line up.
You can also copy/paste data from RR (or other databases) into Excel, then edit the information and save as csv and then import into CHIRP.
ASU6771
Walton, FL
Makes sense!
Thanks Merlin,
Now I need to locate a csv database on this website where
I can try doing that. I’d like to start simple.
Where on this site can i find the NOAA channels.?
nd5y
Wichita Falls, TX
ASU6771
Walton, FL
Any external .csv file that you use with CHIRP must have the column headers in a certain order and data in a format that CHIRP can understand. You can't just copy/paste stuff from RR or other web sites and expect it to work.
I would suggest reading everything at Documentation - CHIRP and everything at UV5R, UV6R, GT3 Info - Miklor.
Thanks for that simple advice, I’ll start there. 👍
Much appreciated.
Jack, Florida
krokus
Southeastern Michigan
Chirp New can pull from this site, and Repeater Book. The weather channels are an option of frequencies you can load, with one check mark.
