On a standard, unmodified radio, the clarifier will have NO impact on your transmit frequency. If it has been modified, your "slider" may be causing you to be off frequency and if the mod was not properly done, there may not be enough adjustment to put it back on the right frequency. If it is a standard radio, there are 2 adjustments for SSB frequency. But you need a good frequency counter and the proper specs to adjust the frequency. Oh, and the pcb layout to know where the adjustment points are.
