pro-106 deleting all programed frequency
geois
iowa, la.
I just bought a used pro106. Can I delete all of the old programmed frequency..
w2xq
Burlington County, NJ
Wirelessly posted (Moto Droid Bionic: Mozilla/5.0 (Linux; U; Android 4.1.2; en-us; DROID BIONIC Build/9.8.2O-72_VZW-22) AppleWebKit/534.30 (KHTML, like Gecko) Version/4.0 Mobile Safari/534.30)
Yes. When you upload a new file, it replaces (not add to) the existing data. If doing it manually, do a total reset as described at the end of the manual. HTH.
jaspence
Michigan
Pro 106
In addition to the info from trsundstrom, be sure to send all of your new data at the same time. If you try to create lists one at a time and upload , the last load will overwrite previous data. The best way is to plan your data, create your lists (up to 20) and send it all at once. Once the data is in memory and working correctly, save it to one of the V-Scan folders. You can have 20 folders, but you can only listen to the one in memory. The V-Scan is like a "parking lot" for other systems and can be recalled easily from the keypad.
