So just to clarify/verify, you have the frequencies for the two Saline Co sites (AWIN database page) programmed in your scanner and aren't picking up any traffic at all? Signal meter showing anything?
Yes they were. They were working then just quit working. Good signal. Not showing the flashing T like im not getting digital anymore. I reprogrammed it. I might have it all jacked up now.
I would use the search feature on the radio and search thru the 800 MHz band and see if the control channel changed from what is listed in the database. If you find that it has changed, please submit a correction to the database.
