nzo012
- Joined
- May 6, 2004
- Messages
- 47
- Reaction score
- 0
As I read some of the comments on the Pro 106 several mention that you should not charge the batteries by using the yellow holder then plugging the radio in and letting the radio charge the batteries with it's charging circuit while they are in the radio. I read that there is no overcharge protection and there is a risk of melting the radio down. It sounds like most people charge batteries outside of the radio with a auxiliary charger and then just swap them back and forth.
When I read the manual for the Pro-106 it says there is a charge timer that you can set to charge the batteries for a specific time limit then shut off.
So, now I'm confused??? Does the radio charge and shut down when it hits the time limit?? Or does it overcharge with no protection and fry??
