Pro-106 using Win500
Franb
I can go into the program and download Johnson county 700 and put on different scan list. Now when I go back and want to do Johnson county to put on lists #6 for KHP Kansas highway patrol I then upload like I do the others but it erases 1-5 but I do have #6? Any Ideals? spring hill, Kansas
Highpockets
Toms River, New Jersey
Everything you want to upload to your scanner has to be in one file. Everytime you upload it over-writes what is in there.
Franb
I'm properly not explaining myself correctly. What did was, I have 5 different banks imported, works great all from the Johnson County 700 MHz p-25. Johnson cnty on one, olathe on 2 etc. Now when I do the the other which is just Johnson County to import Kansas Highway Patrol I do the same procedures and put on a different list and upload to scanner, I lose all info on my 1-5 lists goes blank?
Appreciate the help and patience of all
thanks
Highpockets
thanks
Everything you want in your scanner are you doing it with one upload?
Highpockets
no, one at a time
You are over-writing each time you upload, everything has to be in one file, put all the freq's & systems in one file, enable (alpha tag also) your scan lists you want to listen to, then upload everything at once.
