Pro 164 and WIN 97 software with Trunked system?
dmajors
I live in Lee County, FL and am trying to receive only the Sheriff's dept. frequencies, not EMS, Fire, etc. I have programmed all the frequencies in to the 164 and entered the decimal numbers in to the Channels List hoping if I had Closed checked it would only receive those channels but it still receives all transmissions. Next I entered all decimal numbers and locked each out, same problem, receiving everything. Anybody have a clue what I am missing? I live in Ft. Myers, FL. Any help would be appreciated.
n2mdk
Ames, IA
Are you sure it's set for trunking properly and not just scanning the frequencies.
Check out the p97 file I made up it only has the Sheriff's Dept, it does have Ft Myers PD in sub bank 2 but it is turned off. The bank is closed.
This should work correctly.
  • Lee County.zip
dmajors
I have the following settings, Closed checked, Type: MOT, MOT 800 mhz Normal button, under the RX mode I have FM after trying MOT, MOT received nothing just scanned? As you can tell, I am new to the scanning community.
