Pro 164 tuning problem
kcvanover
Philpot, KY
I finally got my Pro 164 to track EDACS. I had to add .025 Mhz to all the channels. This appears to only be a problem in the 800 Mhz band. I used WIN97 to program the scanner. Anybody know of a fine tuning setting I might have accidently adjusted?
thanks
KC5EIB
Flower Mound, TX
Are you trying to program in LCN 3 as 852.31250 but can not get it to work? What frequency are you programing into the scanner?
kcvanover
Philpot, KY
For example, the current control channel for Owensboro KY is LCN 07 853..8375. I had to program 853.8625 for the scanner to hear the data clearly and decode the system. I adjusted all channels up .025, and now it works??????
