This being GRE manufactured Scanner sold under the RS Realistic name, I elected to place this here especially since RS sold so many scanners over the years.
Out of nowhere when I went to use this (last time was around a month or two ago that I used it) the when I went to use this, the O/S apparently was corrupted showing a blank display (other than the backlight), no audio (other than the normal 'pop' when it was powered up), no squelch action (no inter-station noise), no response from any button and no response from my signal strength meter (Bill Cheek mod) which the needle will usually will bonce around as it is scanning.
As in basically toast/fried as in dead other than a slight 'pop' in the audio when it was turned on and the backlight.
The 1st thing I did was to check the memory battery which was low, but NOT dead. I replaced it, but little change. With nothing to loose, I did a reset and it came back to life, but I lost all the memory.
So my question, has anyone else had anything like this happen and why on earth would a 'low' memory battery cause this???
BTW, I live in a city than never has lightning issues and my equipment is grounded, no static related discharges to the radio.
