Pro-2055 Volume & Squelch Knobs
shirsch101
West Chester, PA
On a Pro-2055 I need to remove the volume and squelch knobs to lubricate so they don’t stick. Which knob comes off first the center or outer ring
Steve
buddrousa
Pull the center off with your fingers and use the butter knife on the outer knob.
You were given bad information for cleaning and maintaining electronics.
So if you do not want to take my advice you can wait for others.
shirsch101
West Chester, PA
The knobs don’t turn separately both turn together. The inner and outer shaft are rubbing each other and get stuck together
buddrousa
I had a PRO197 do the same thing I had to remove the controls out of the scanner the center shaft was bent I had to strighten it then clean the controls that were gummed up with the correct cleaner then replace it back in the scanner.
buddrousa
The difference between Contact Cleaner and WD40 is that WD40 is an Oil and will attract Lint Dust Ect and gum right back up.
Contact Cleaner sold at Lowes will clean and Evaporate leaving the controls to work longer and better.
  • Like
Reactions: wtp
TGuelker
Retired ASE CMAT L1 MRRT
Collinsville, Illinois
I had two Pro2096 scanners that did that. Tried several things but the shafts like to turn together due to age and poor design. Over the years the shaft bends just enough to cause this problem. The control is no longer available. I saw where someone made a small rubber washer that went behind the squelch which increased the effort necessary to rotate the knob. I got tired of holding the squelch while I rotated the volume.
gmclam
Fair Oaks, CA
If the shaft is bent too much, you might consider just replacing the pot. There's all kinds of tricks you can do so the knobs don't stick together, but that's on a straight shaft / good pot.
Nasby
Ohio
Be very careful when trying to straighten the bent shaft. It will snap off quite easily.
Ronaldski
MI DB Admin
Bay City MI
As mentioned above I fixed another's radio with electronic cleaner from radio shack i got when they were closing stores. Sprayed around it and rotated it, did it again as well works good now.
Yanking out parts suseptible to damaging it beyond repair.
