Date: Sun, 19 Sep 2004 04:46:11 -0700
Subject: RE: Re: Problems writing new freqs w/ Win92
> Don't believe I've even noticed that column before. You mean that
> I can enter a freq and an alpha tag for a channel, and the program
> still considers it as "unused"?
Yes, and so does the scanner.
> I don't recall ever having to deal with that before, but I'll watch
> for it from now on.
It's been there forever
> For my edification, what is the purpose of having a way to mark a
> used channel as unused. I would have thought that locking it out
> would be sufficient.
The scanner has two flags for each channel: one that indicates the
channel isn't programmed with a valid frequency, and another for
the lockout function.
> What would happen if I unchecked the "unused" box and there wasn't
> a freq programmed.
You'd see 29.0000 MHz programmed into that channel on the PRO-92.
The PRO-92 cannot actually hold a frequency value of 0.0000 MHz.
When it's displaying 0.0000, it really has 29.0000 plus the "unused"
flag.
Win92 could probably clear that flag for you if the channel contained
anything but 29.0000 MHz, and set it otherwise. The problem with
this would be if you actually _wanted_ 29.0000 MHz.
-Don
