I have 1 channel operating on the PRO 2096 and everytime I try to program the scanner it goes to the code Heap error 21f921:2200. I do not have a reset on the back. I just need to know if this thing can be fixed or do I have to send it to the dump.
I tried to google the code and all I got was for the computer os. where did you find the solution to 21f921? The only way to input any button like FUNC,MAN, PROG etc. is to turn off the scanner, hold down the button and turn the scanner on. Still I can't Program.
Please utilize the thread subject as a quick summary of what your thread is about rather than inputting your username. This makes scanning the forum thread titles easier for readers. Thanks. (Subject updated)
Dont do an internet search on that as you will get mostly nothing related to radios.
Do a search on this site - in the upper right, very popular question,
Essentially you have a talkgroup that is not assigned to a scan list. RadioReference.com - Heap Error
Heap Errors are most often caused by one or more talkgroup (TGRP) objects that are programmed into the radio, but not associated with any trunking system (TSYS). When programming an OOUI scanner by hand, this can happen when a new TGRP is saved without mapping it to a new or existing trunking system, e.g., pressing the Save softkey when "NEW" is displayed in the TSYS field of the TGRP object menu.
To correct the HEAP ERROR condition, look for any TGRPs that have "NEW" as their TSYS, and delete them (press FUNC CL) or associate them with a new or existing trunking system.
