Pro 651 with Danecom - no joy
swm239
Hello, I am wondering if anyone around Dane Cty has a Pro 651 and is able to hear anything on Danecom?
I am hearing it well on both Pro 106 and Pro 197 as well as a few Unidens. I friend picked up a 651 and I copied my program from the 106 / 197 to his 651 and it does not pick it up. Have them sitting right next to each other and again the 106 works the 651 does not. ATT is not on, I had all 10 freqs listed and then changed it to just 3 ([potential data channels), I see between 4 to 5 bars on both radios, I do hear some WX channels when searching. I do not see the "T" icon. Quite puzzled by this and curious if anyone has any thoughts. This appears to be something with the 651 as the others seem to be working well.
Thanks,
Scott
R8000
Very Low Battery
I'd recommend having both scanner codeplugs up side by side and go through each screen to be sure all settings were copied. Make sure your "System Tables" are set up correctly. I have a 652 and it's working pretty good.
