pro 95 trunking question
gaunter033
I would like to know if this is possible with the pro 95 using win95 and if so will it work like I am thinking it will.........which is, as I drive thru the cell areas, I will pick up the local talk groups I put in?
I want to put certain control frequencies only for certain cell cites that I want to travel thru in south carolina in bank 9. OK, now once I install all of the ID codes for those areas that I will travel thru and I am sure that everything is in motorola type 2 mode and I close the bank do I need to change anything in the upper right hand corner box where it says "Motorola UHF-lo settings" or no? Sorry if this is a dumb question but I want to be sure I get it right the first time.
Its a motorola type 2 smartnet analog system on the palmetto 800
scanfan03
Houston, Texas
If it is 800, then no. Also be sure if it is a Type II system, that all of the boxes in the Fleetmap area display "Type-II".
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
You're probably referring to Palmetto, if so, some id's may be digital, simply lock them out if the come up. Don't forget them though, they may not be digital on another tower.
Edit: Ah, you indicated Palmetto.
INDY72
Indianapolis, IN
For the Palmetto 800, all you have to do is set the bank, and each chan to MO for Motorola.... Program in iether CC only for the towers you need, or the entire list for the tower you want. In the other block, go with the default setting which is for a Type II 800. Then add in the TG's you want to hear....do not put in digital TG's. Then set the bank to closed mode. Also be sure you do NOT put delays on the repeater freqs.
