Pro 96 voltage?
ind224
Indianapolis
The 4 AA holder would be 6v yet the charger/adapter feeds the scanner 9V.
Can I go 12v without a problem?
Also after repeatedly dropping the unit the power feed/charger jack is inop. If I plug in the adapter nothing happens. I need a schematic so I can check the board and the jack. Knowing the SMT components would be helpful,too.
Help??
Thanks,
Stu
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
I think the 9v is to allow for higher current during charging cycles. A 6v charger may peak out regardless of it's mw rating. I wouldn't use a 12v supply.
ind224
Indianapolis
Infinite heaps of thanks Frank. Touched up the joints on the board. Still no go.
Made sure the plug and jack were making. Tip OK but neg side inside the jack has been pushed out away from the center pin. Looks like I need to replace J3 eventually. A dab of solder on the outer of the plug makes contact 100%
Thanks again!!
Stu
fmon
Eclipse, Virginia
Thanks again!!
Stu
Glad it works. Which Adapterplug are you using, B or C?
ind224
Indianapolis
Not sure. It fit correctly before the bashing and has a bright yellow insulator if that helps ID it.
Stu
Rat
SW Pa
What is the correct adapter??
ind224
Indianapolis
Well, they have changed the tips. The one I had was old and was all black with just a + /-not the actual ID on it.
The new ones are white with the letter in black and the +/- but they all had yellow insulators.
I thought the old ones had different color insulators?
And just to be sure B or C is correct? My C is working great and J3 seems to be just fine now.
hoser147
Grand Lake St. Marys Ohio
Radio Shack 12v adapter
Dont know how much help this will be but i run the RS Ciggarette lighter plug to power mine when in the car it also uses the adapta plug on the end it appears to be just a standard lighter plug but i dont know. What i do know is ive ran my 95 and 96 both with no problem.........Best of luck Hoser147
aaronp
6v versus 9v
You'll notice on the schematic above that the voltage input has to pass through a diode. See the 9.0 in the circle at the input, then the 8.2 in the circle just past the diode?
The diode and filtering circuitry drops the voltage .8 volts.
If you used a 6v adapter, after it passed through the diode, you'd only be getting 5.2 volts into the radio. This would probably be enough to run the radio, but you wouldn't be able to charge the batteries fully.
I don't think current is the issue, since you could, in theory, get a 6volt adapter that supplies pretty much any current you were looking for.
In order to know if 12volts would be ok, we'd need to see more of the schematic. Does the voltage go on to a voltage regulator (if so, maybe 12v would be ok).
Without knowing, I wouldn't recomend 12v.
When I got my Pro96, I picked up a 12volt adapt-a-plug device that outputs 9 volts. It works great, and I don't have to worry about frying my $400 scanner.
I'd really like to get my hands on the rest of that schematic.
EDIT-
A search of the internet turned this up: http://www.strongsignals.net/access/boards/viewpost.cgi?board=pro-96&num=4709&archive=0105
"In Reply To: AC Adapter Re-visited posted by Wb8wcz on December 8, 2004 at 18:48:20:
The PRO-96 contains three voltage regulators on the input power supply. They all regulate power from both batteries and an external power supply.
One regulator is an AN77035. It supplies the digital section (CPU, DSP, etc.). This has a maximum input voltage of 30V.
Another is a TK11235CUCB. It supplies mostly the RF and audio sections. It has a maximum input voltage of 16V.
The third one is a BA05FP, and powers the audio amp for the speaker and headphones. It has a maximum input voltage of 35V.
If you stay under 16V on your external power supply, you won't hurt the radio. An unregulated 9V 1000mA wall wart that supplies 15V when unloaded (or when only loaded with a 300mA current draw) is fine. "
Temelin1
Geneva, NY
AARONP: That was a very interesting summary of the voltage regulator ratings for the PRO-96. I have the same question on the PRO-164. The PRO-164 manual says to use a 9V supply with at least 400 ma current load capability. I pulled out an old adapter that says "9V, 400mA". I measured it unloaded and it read 15.26V. Then I put some resistors in series to get it to about 22.5 ohms (for the 400 mA) and it read 9.2V. However, I am worried that if I run the unit without batteries (i.e. no charging current which I assume takes up the lion's share of the load), then the voltage from the adapter to the PRO-164 may be too high. Can you tell me where I can see a schematic for the PRO-164, or do you know what the regulators in that radio are rated for? Thanks.
