pro-96 win96 extended tables?
scanland
Alaska, Anchorage
How do i get the win-96 to perform correctly? I can't quite figure out the Channel Hi And Channel Lo option. Do i put my offset value in the channel low, and the default value of 65535 in channel hi.
kikito
North Pole, Alaska
scanland,
It seems that for our system up here it's mostly backwards when it comes to the channels in the tables. In my "experimentation" I found so far that the higher the control channel frequency, the higher the Offset value I need to put in to make it track which also makes the Lo and HI channels I put in the extended tables higher too.
Example:
CC: 154.665 uses Offset of 25935 while CC: 156.0975 uses Offset of 38250.
The help file on Win96 has a good general explanation for extended tables, which is where I got many ideas to try on our system....
