Pro 97
CMale0624
Miami, Florida
Well, I finally got my scanner back from RS and the screen is showing frequencies now. Problem is now that I pushed the weather button to listen to some report's on bad weather moving in and now it won't clear from that frequency. I tool the batteries out completely hoping that would clear it and even switched from AC to DC power but no luck. I see in my manual that there's a way to "Initailize" my scanner and even tried that but no luck. I'm losing more faith in Radio Shack scanner's everyday. Anyone out there in Cyber land got any idea on how to clear this weather frequency that's stuck on my dial?
GrayJeep
N. Colo.
The fixable possibilities that come to mind are:
Push SCAN (I bet you tried that already)
The WX button is stuck down. Push it, wiggle it, mess with it. (does it change if the antenna is removed and the squelch is turned up tight? If it does, then the button may really be the problem. If not, then I dunno)
If resets per the manual don't work then your radio is broken. (unless someone can suggest something else)
