Most of Henry Co. looks to be digital, it says that they dispatch fire on anaolog but that could of changed. Other than that , the 97 will not pick up the digital that they are useing. Hope this helps
thank you all for all the help..do you happen to have the freq for HCFD dispatch the dispatch freq i have found i am not hearin nothin might be my fault i dunno lol.
Andrew is saying that you can put the EDACS system into the scanner. You will only be able to hear the dispatch. Put the frequencies in red( the CC's) in the bank slot that you will be programming it. Example: bank 0; 004, 005, and 008. Then program in the TG for FD disp and any other TG that has an "A" after it. If it has a "D" after it, it is digital.
HTH,
Larry
