Pro Scan 651 Software
tinacoons
Hartford City
I bought the software online from radio reference and never could get the driver or software to work..I want a refund on this $54 I paid . How do I get this back? The process was the most frustrating one I have ever had!
fxdscon
¯\_(ツ)_/¯
Can you be a little more specific on exactly what software you have and where you purchased it? Is your scanner the Radio Shack PRO-651?
Radio Reference does not sell the ProScan software, and the ProScan software is not meant to be used with the PRO-651 scanner... it won't work at all.
If you're talking about the ARC500 software from Butel that you purchased from Radio Reference, It does work very well. There are many articles here on the RR WIKI that will help you to understand how to install the drivers and use the software. Your scanner is the same as the PSR500.
Connecting scanners via USB - The RadioReference Wiki
As far as refunds, if you did purchase the software from RR, this was part of the purchase form that you had to put a check mark in when you purchased the software:
"I understand that refunds are not available for software license purchases or RadioReference premium subscriptions."
tk000
Central Ohio
And this is definitely the wrong forum.
mikewazowski
Forums Manager
Oot and Aboot
Since the member bought the software from RadioReference, than this forum would be the best to ask for a refund.
Of course, to download the software you need to accept the terms which states that refunds aren't given.
tk000
Central Ohio
I was referring to the forum for "System-wide Administration Support for issues related to subscriptions, server connectivity and commentary, and layout usability"...which I don't think is the correct location for such a complaint.
joeuser
The Wretched
North Central Kansas
There ya go thinking again!
INDY72
Indianapolis, IN
Issue reported to senior mods, should get fixed pretty quickly.
mikewazowski
Forums Manager
Oot and Aboot
Since this is a problem with a product bought from RadioReference, it belongs in this forum.
No further comments are necessary.
dmmalish
eaton rapids
same problem here purchased software after buying scanner pro-651 and cable at radio shack but cannot get it to work very frustrating
mikewazowski
Forums Manager
Oot and Aboot
Perhaps asking for help in the correct forum would be a good start?
