Pro-Scan Help Needed
mondaro
Harrison, New Jersey
Hello,
just got my computer back and trying to put a feed back online.
Using proscan, when trying to connect the scanner back on
line I am getting a pop message of
Source Client
Set the input sound device to a valid input located in the auto control tab.
If anyone can help out with this I can get the feed back up and running.
Tony
mondaro
Feed is back up and running just adjusted all the levels in the auto control tab
and i was good to go.
Thanks everyone.
Tony
rcool101
Eastern Ohio
Was it your hard drive? and did you change it? I think you said you had something froze up
mondaro
Yes, on the Dell computer the hard drive failed and had to be replaced. Took it to my IT guy its was repaired on and the feed is back on the air. I came home to a frozen screen on Thursday night, tried a reboot
went through a series on test and the result was the computer could not find the hard drive,
My IT guy told me that Dell had an issue with these hard drives and he was not shocked to see my computer come into for repair. Just happy the feed is back up and running.
