I got the win93 scanner software fpr the pro 2053. I went and got the radio shack cable for it (20 466) and also the 3 dll files for the win93. I installed the driver from the cd and the port is 15. I set the port to 15 in the win93 and when I try to read the scanner it says timed out waiting for the header. I have tried it with the mono adapter and without for grins. Is the com port too high? I recall in some devices a higher com port wpuld cause issues and you'd have to try to use a lower com port. It is the usb cable from rat shack. I got it after building a home cable and nothing. The driver it had originally the homemade was a 2006 version and this one was the 2009 version driver. Still nothing. Any thoughts or pointers?
I should add that the version of the win93 is v00.31 I tried the pro93.com but it was a non working site that the radio shack site listed. I checked the radio shack cd that came with cable but didn't see a pro 93 or 2053 with the arc version software.
