Problem inserting new data
Spitfire8520
Might be slightly less clueless! =)
Colorado
The section heading needs to be alone. No text can follow it or you get what you are seeing now.
Correct:
Code:
== Cuyahoga Valley ==
Dispatched by Chagrin Valley Dispatch Center
Incorrect:
Code:
== Cuyahoga Valley == Dispatched by Chagrin Valley Dispatch Center
Also you need to make sure your sections are using the same level of heading, or they get added as a subsection of the above.
Correct:
Code:
== Cuyahoga County Sheriff's Department == (3.6)
== Cuyahoga Heights Fire == (3.7)
Incorrect:
Code:
=== Cuyahoga Heights Fire === (3.6.1)
Correct:
Code:
Incorrect:
Code:
OK that was it. I thought there was an instance with the text after and it wasn't a problem but anyway...
The other thing fixed itself since it was not related to the sheriff thing.
Thanks!
