Problem with RX on VHF Quantar
wgbecks
NE Wisconsin
You've received some excellent advise. I'd suggest retesting with the original jumper cables in that the new jumper cables may not be fully shielded as were the original beige colored cables. Improper shielding will allow radiation of the transmitter’s energy to couple into the receive
branch causing desense and possibly into other cables and electronics.
LCT123
Funny you should say that, I am in the middle of bad thunderstorms and I just realized my weather radio will barely receive. It was connected to the quantar receive antenna. Must have got the weather radio like you suggested. I have learned a lot tonight.
wa8pyr
Staff member
Lead Database Admin
Ohio
That is what I am referring to.
Really needs to do an on site duplexer tune and proper ISO-T test.
Many people think tuning duplexers on a bench and shipping them off are all it takes. Hardly the case.
Feedline choice is also critical in duplex systems.
Concur, align the duplexer. Even being off just a bit will seriously screw up your performance.
I've had experience with those dB Products duplexers, and they didn't hold up too well to shipping; I always had to do a touch-up alignment on site to get it spot on. And if it's the model I'm thinking of there isn't a huge amount of isolation to begin with, which means even a slight bit of misalignment will seriously hork up your repeater performance.
prcguy
So what if the receiver is actually bad and you just wasted time tuning a duplexer that didn't need retuning? That's why testing and verifying the receiver is #1 on the list. Once that is verified good and if the problem still remains, only then do you branch out and test the next most likely thing in the system, which may be the duplexer.
wa8pyr
Staff member
Lead Database Admin
Ohio
I intended to imply testing the RX first; so many people mentioned it that I didn't really get into it.
But based on my post-shipping experience with those dB Products duplexers, I'd check the alignment on the cans anyway just to make sure.
LCT123
The model is a DB4058-A
