Problems with CQPSK scanning
airboss20
Horseheads, NY
My county has recently upgraded to a UHF P25 system that simulcasts using the CQPSK standard. That being said, the tac channels are all analog. The Grants/Bonds were not sufficient to replace every radio in the county and we were left with the option of purchasing our own radios. We could have rode the bid and purchased new radios from MOTO for $1500-$3000 each, or acquire surplus radios from other means for a fraction of that.
We decided to obtain several XTS3000 portables and Astro Spectra mobiles as they are plentiful and simply replaceable vs repairable at their current costs. In operation, both models operate flawlessly, until they attempt to scan. The P25 channels (3 of them) are set to the correct modulation, normal squelch, fast unmute, Non Dynamic Scan, Non Talkback and Selected Channel Priority. We have 8 channels total, the rest are analog.
The radios have no issue picking up the analog channels on scan, but even if I am set to a P25 channel (which would make that channel priority) it misses entire transmissions on all P25 channels, or hear only small parts of the transmission.
I have attempted many different settings but none seem to improve their performance. I have owned many of these models in all bandsplits, but never encountered this issue before. This is the first time i have encountered the CQPSK standard though.
I would be greatful if anyone has a solution to this issue.
Thank You.
radioman2001
New York North Carolina and all points in between
When was the last time the radios were aligned. I have found any radio of that generation I have bought used to be off frequency due to age. P-25 is a little more finicky than analog on decoding, and also what firmware are the radios, the later the firmware the better for decoding especially CQPSK. You can also try setting the squelch from Normal Squelch to Digital Carrier Squelch to see if they receive any better.
airboss20
Horseheads, NY
The Firmware version is 07.12.00.00 and DSP is N08.02.08.
It works well without fault when not scanning and alignment is good as confirmed with my HP8924C.
