Programmer R18 Help
BillKaye
Albuquerque, NM
Hope that someone may be able to point me in the right direction . . .
My objective is to clone my Jag700P system model to a LPE-200 system model, using Programmer R18.
I read the Jag personality into R18, changed the “Radio Type” from Jag 700P Sys KRD103161 to Prism HP/LPE, and wrote this to the LPE-200.
The original program on the Jag uses 13 of the 16 group sets, and I am able to turn the 16 position knob to cycle to different sets and lock in where I can scan just that group.
Issue 1 ---On the LPE-200 when I turn the selector knob I am not switching between group sets but rather it seems to cycle through the group name.
Issue 2 --- If I depress the left up arrow button I can see all the group set listed and these seem functional only on the first five. The sixth through thirteenth will show the group name an then the screen switches to ‘INV SYS’.
Any ideas, suggestions, workarounds . . . . . .?
Thanks, in advance, for your help
ElroyJetson
It's in the keypad and knob options section.
You can go to that section and select the function of various controls on the radio.
For scanning use, my standard setup is to assign different agencies (systems) to the two side buttons and assign talkgroups to the up/down buttons under the display. I totally ignore the rotary switch, it is actually quite useless for a scanning radio in this configuration.
