Programming 700 mhz channels.
Davey1
Bowling Green, Ohio
I'm wanting to program three of the 700 MHz Nationwide Interoperability Channels into my G5. I can't under the settings that I need to use to do this. Are these programmed as conventional frequencies or P25 conventional frequencies? Which protocol do I need to use? Is a specific talk group used? If I try to set them up as P25 conventional it asks for a talk group but I can't get a dropdown to set one.
The three frequencies are:
773.50625 known as 7Fire83D
773.85625 known as 7Fire84D
773.00625 known as 7Med86D
Thanks in advance.
BenScan
D/FW
Gotta get ready for work, but here's a quick selection of PPS screenshots that will hopefully help.
Can't remember if this one below is really required...
Honestly, it's been a while since I've done this, and I don't recall the Talkgroup List area that seems to be auto-generated by PPS.
Hopefully, that's enough to get you going.
Ben
